21 - 24 of 24 Posts
2015 Forester Ltd cvt
Discussion Starter · #22 ·
I had a seal problem at the bleeders. They were corroded. I then purchased 4 Stahlbus one way valve bleeders and it was one and done. Worked like a charm. Nickel plated. Made in Germany.
I was getting air bubbles no matter what I did. Also, there is a sequence for each vehicle. Not always intuitive. My 2015 starts with the right front.
see
What size bleeders? How much did they cost?
The Stahlbus bleeders are not cheap. They’re made in Germany. Well made. About $105 for 4 with caps. They’re all 10mm. Same as Forester.They come in different colors. Go to the Stahlbus website. These bleeders have a one way ball check valve. Fluid only moves one way and no air is sucked back. One man operation.
Discussion Starter · #24 ·
Wow. I have Speed Bleeders on my bikes brakes and clutch; about $6 a piece.
21 - 24 of 24 Posts
