I have never replaced rotors before so sorry for my first silly question. I plan to replace because I am getting some wobble when braking at high speeds, one of the pads has a squeal - I am sure it's the wear indicator. I plan to just do it all at once including new brake fluid - DOT-3.
Looking at the Subaru parts site I see two different front rotor sizes "16″" and 17″" that are specced for my car. On Autozone etc, I am seeing many different sizes of rotors that "fit" my vehicle some are 294mm or ~11.5 inches others larger.
Oh, and do I need to match up the pads to the rotors or does it not matter?
I am sure I will have more questions as I work through my purchase list.
*17 inch rims is what I have, if that is how Subaru is differentiating between rotor size by using rim size?
An aproximate measurement of the front rotor is a bit more than 11 inches without taking the wheel off. So I am guessing it's the 11.5 inch rotor I am needing, but Subaru doesn't mention the rotor size anywhere.
The rear rotor size? Again different size on the aftermarket sites
TIA
TIA
