1 - 15 of 15 Posts
2014 Forester XT Touring CVT
I have a 2014 Forester XT 2.0 Touring, (purchased new), with 19,000 miles.
I have started to notice an engine or possibly a turbo related noise that occurs around 1,000-1,200 RPM. It occurs as the engine is decelerating from a higher RPM, as when pulling in to a parking spot.
Once parked, I can accelerate in/around the 1,000 RPM range and duplicate the sound. Dealer says engine sounds normal!
Do any of you Turbo owners have a similar noise?
Thank you,
Mark
Sent from my iPad using Tapatalk
‘14 FXTT; '15 Legacy FB25
Need more info re: noise...
2017 Forester XT Touring CVT
Thank you,
Mark
Please record noise the best you can and post to youtube then post link.
i complained of a knocking/ ticking noise that was very faint. dealer tech related it twice to the
"noisy high pressure fuel pump, because it is mechanical and runs off the cam"
i also only notice the noise in warmer temps. what about you?
2014 XT Touring
I'm also interested in the noise, OP. I have the '14 XT Touring too. Please do try to upload a video of the noise! Thanks
Discussion Starter · #9 ·
Noise is present even when temp is 50-60F
Discussion Starter · #11 ·
Sorry for the long delay in responding!
Subaru technician advised the noise is from the High Pressure Fuel Pump. After seeing the thick foam installed around the fuel pump from the factory...I am in agreement.
I am going to follow up with Subaru Customer Services...to see if there might be a new improved fuel pump that is quieter.
Discussion Starter · #12 ·
Regarding noticing the noise in warmer temps...it is cool weather now, the noise remained the same. However, in general, I feel the noise level has increased in the last 500 miles.
Discussion Starter · #13 ·
I will see if I can record the noise on video and upload.
Did you see my follow-up post? Subaru tech says the noise is the High Pressure Fuel Pump.
he pointed out that the HP Fuel Pump came from the factory with foam rubber wrapped around it...an attempt to quiet the noise!
13 forester 2.5 & 14 XT 4eat/ CVT
I might be having a similar noise with my 14 xt its only noticable when its cold however.
Sent from my LM-Q710.FG using Tapatalk
2016 Forester XT
I have a 2016 xt. The noise is very noticeable at about 1000 rpms on colder days. Once the engine has been on for a long period of time the sound is almost unnoticeable. I brought the car to the dealer and it seems like only the xt has this problem. They cant seem to pinpoint why its making the noise. I left it in at the dealer for over a month. On warmer days you can still hear it. I live in nyc, in the winter months if you dont have your radio on or heat on you will definitely hear it.
1 - 15 of 15 Posts
