@TonyW1963 note that @lakarz16 last signed onto the forum 8 months ago. You could send him a PM - Private Message... now called a "conversation" on this new site. He's optioned to receive an e-mail notification, so you could receive an reply.
2915 Forester...me too. Reservoir filled but light still on. ??Hello! Can you help me solve the problem. My windshield washer fluid light is ON always on the panel but the my washer fluid tank is full. Thanks for the help!
Unless the low level sensor is built into the washer pump itself, I can't find any sensor in the washer tank.anyone found a solution to this?
There is a float switch at the bottom of the reservoir that closes a circuit when the float drops due to low fluid level. You can disable the light by reaching around the rubber flap under the driver side bumper, feeling around the bottom of the reservoir for the 2 wires going into the connector that goes to the float switch and disconnecting it by pushing in a tab and pulling downwards. Just let it hang and you’ll see that the washer light comes on when you start the vehicle and then goes off and stays off.Unless the low level sensor is built into the washer pump itself, I can't find any sensor in the washer tank.
Maybe its a maintenance schedule reminder thing. Just like how you can set up oil change or tire rotation reminders. I'll check it out on my car the next time I drive it.
