@thaoneguy, swapping the entire headlight assembly is really expensive. New headlight units are around $800 a piece. You can always try Ebay for used or aftermarket headlight assemblies. Usually the used ones have broken tabs or scratched lens. There are two more economical options if you want brighter headlights or projectors.
Option 1 Projector Retrofits. Do a retrofit using the current headlight housing. A popular option is the Morimoto D2S Projectors, You can then pick your shrouds and halo ring options. Cost wise without halo rings you are looking at around $400 all in with bulbs, ballasts, wiring harnesses, etc.
This is a pretty substantial DIY project that is not for the faint of heart. It usually takes about 3-4 days to do this conversion yourself. I have thought about doing this conversion but opted not to do so due to cost and potentially needing a new set of headlight housings if I messed anything up beyond repair.
Check out
The Retrofit Source | The Best Brands in Automotive Lighting they have everything you will need.
Option 2 keep your current headlight housing. Instead of doing projectors get a set of H11 LED low beam bulbs. Either go with the Diode Dynamic SL1s. Or the Morimoto 2Stroke 2.0s. With LED bulbs you need to purchase a set that are corrected for original halogen filament placement so you have the crisp cut off line and are not blinding oncoming drivers. The cheap amazon and ebay LED bulbs do not pass this test. Both the Diode Dynamics and the Morimotos have the LED chip placed in the original halogen filament placement. Cost wise bulbs and CANBUS drivers will run you about $150 - $200.
I am currently running the Morimoto 2Stroke 2.0s. They've been in my car for about a year and a half now, and have great color and brightness. The DD are comparable in price, color and output.
There are other threads on putting a set of 2017 touring projector headlights into the SJ's with halogen headlights. Just like the XT headlights you will have to rewire / pin the connectors to make the new headlights work with the current system.
('14-'18) - 2014 - How to: Swap in 2017 LED...
