1 - 10 of 10 Posts
2014 Forester 2.5i, comfort trim
I have some rough idle issues on and off with the 2014 Forester 2.5, car is 86000km old.
Would like to order seafoam and try a treatment through the air intake
I am not sure be safe to use seafoam on Subaru engines , has anyone used that ,
What is your opinion?
Thank you,
2019 Tacoma TRD OR 4x4 6AT
@ziy2014 I think it's safe, but difficult to say if it will solve your rough idle problem. ~53k miles is relatively low for carbon build-up to be an issue on a port injected engine. My guess would be that your spark plugs might need changing.
Have you kept up with regular maintenance?
2016 & 2018 2.5i Premium CVT
Seafoam used to be a favorite discussion topic here, a long time ago. IIRC, nobody reported any problems.
Hi
I picked up the car 4 weeks ago and the records show that the plugs were replaced in October last year.
Right now engine idles at 700 rpm in park and 600 in Drive with shaking and sensable vibration when I am stopped at the red light .
Should I suspect the engine mounts if cleaning throttle body and doing idle relearn does not help?
2014 Forester 2.5i CVT
I'm not in a position to tell you that your Subaru doesn't have a problem. But ...
The Subaru boxer engine doesn't idle as smoothly as in-line 4-cylinder mills. A little stumble or two at a light is not a problem.
2012 XT Touring 4EAT
<snip>Would like to order seafoam and try a treatment through the air intake
I am not sure be safe to use seafoam on Subaru engines , has anyone used that , What is your opinion?
I've used it and I think it's safe. I'm not exactly sure how necessary it is, if you use the recommended gasoline.
All of my Subarus were purchased used. I really had no way of knowing what kind of gas had been used (turbo cars like 93 octane gas - and may collect a bit of carbon at lower octane). So, a can of Seafoam - half through the tank and half sucked into the intake - was simply a way to clean out the carbon cobwebs.
And, you might look for vendors of TopTier gasoline. It has additives to clean your injectors and generally keep the cooties out of your engine.
2015 Forester 2.5i Premium 6-speed manual
Check for loose or damaged spark plug wires. Maybe even pull the plugs and inspect their condition and if they are the correct heat range and type of spark plug. Check for vacuum leaks and cracked or disconnected vacuum hoses.
With car repair, The Basics, first and foremost.
2015 Forester
Hi all,
Should I be concerned if using SeaFoam in the intake of sogging the cat?
Thanks!
Discussion Starter · #10 ·
Just to give an update about the rough idle issue,
I replaced the pcv valve yesterday and seems like the problem is gone.
Old valve did leak when tested it
1 - 10 of 10 Posts
