1 - 2 of 2 Posts
2014 Forester 2.5i
2017 Forester XT
I installed the hella sharptones on my 2017 forester xt a few weeks ago. You don't need a relay because our cars already have one and you don't even need a wiring harness or bracket. I just unplugged the old 2 horns, removed them, and connected and mounted the new horns in the same spot where the old horns were using the same wiring. All you need to do is run 2 ground wires (one for each horn) from one of the prongs on the new horns since they are 2 prong instead of the OEM's 1 prong. Ground them to a nearby chassis bolt and you're good to go.
1 - 2 of 2 Posts
