2019 Tacoma TRD OR 4x4 6AT
Out of curiosity, does anyone here know (ball park) what the replacement cost would be for a stock FB25 engine? Preferably a factory built or factory re-built engine (not junkyard pull). Is this even possible now that this engine has been superseded by the FB25DI?
Thanks
2015 2.5i Premium
It is still easy to get one. The 2019 Outback and Legacy still use the FB25. It will still be available long after they go to the FB25DI. It is the same engine just with a different fuel injection system and modified cylinder heads to accommodate the direct injection system.
As for pricing, if you had it done at the dealer ,I would think it would probably run at least $8k-10k.
