1 - 18 of 18 Posts
2014 2.5i CVT
Table of Content:
Details @ Purchase:
  • 2014 2.5i CVT
  • 55300 kms
  • Stock standard ATM, apart from the odd item listed in this post...
  • Retrofitted Subaru reverse camera
  • Std. 225/60R17 road tyres on std. 17x7 steel wheels
  • Tow bar by Subaru...
  • Rhino roof rack and basket (basket removed for now)
  • Pre-purchase fixes: outer RHF CV boot, Subaru recall replacement of rear coils, 42 month service, minor fixes...
Wants/To Do:
  • Fix "Fill Washer Fluid" warning light always on
  • Investigate possible missing wiring loom cover
  • Rear cargo step protector and other misc. bits... dash mat, phone holder...etc.
  • Investigate audio drop outs Bluetooth <=> Android
  • Upgrade to 225/65r17 or 235/60r17 AT tyres
  • Investigate front right knock while turning right at low speed
  • Window socks for camping, now, ASAP, yesterday!!! (ordered)
  • OBD II Car Head Up Display/phone app.
  • Permanent phone holder to replace air vent style phone holder
  • Matson battery monitor
  • Weather visors driver/passenger front and rear windows
  • Boot cargo mat and nets
  • Fix damaged plastic bits - drivers seat kickplate, drivers air vent, front passenger skirt...
  • Upgrade bash plate, i.e. Suba Xtreme full length "Sump & Transmission Guard" or similar
  • Anderson plug install at rear
  • Swing away cup holders
  • Sport exhaust - full or in part to bring out flat-4 rumble if possible, i.e. unequal length headers...etc.
  • Adjustable height suspension - coilovers, airbags...???
  • ...many years later - EZ36TT swap ;)
545748
Reactions: Boxa_2009
2014 2.5i CVT
New plan - EZ36TT swap first, divorce 2nd... ;)
Reactions: Kevin and sneefy
2009 Forester XT Obsidian Black Pearl 4EAT 99.7% stock
She's a beauty! What do you think of the CVT? I like how they work now compared to when they first came out
2014 2.5i CVT
Thanks @Boxa_2009 - the photo doesn't do the colour justice, but I had to up the exposure to see the Fozzy in a shady spot...
CVT seems good, compared to earlier versions for sure. I'll take Fozzy offroad sometime over the next month so will be able to test it out and X-Mode too. Tyres probably won't be upgraded at that time, but that'll give a baseline for tyre comparison later. Cheers
2014 2.5i Limited CVT
... and that's the last year of that color (called Marine Blue Pearl) for the Forester. 2015 swapped out to quartz blue...
At least here in North America. My own 2014 Forester 2.5 Limited is also the Marine Blue Pearl...
545786
There's a lot of mods... but no engine swap.
2014 2.5i CVT
Discussion Starter #8 (Edited)
Fuel Usage Log...
91 Octane Petrol (Australia)
Country Driving:
Combo: 8.7 L/100 kms (27.0 MPG / 11.5 km/L)
City Driving:
Towing 50%:
Towing 100%: 11.1 L/100 kms (21.2 MPG)
E10 91/94 Octane Petrol (10% ethanol, Australia)
Country Driving:
Combo: 9.1 L/100 kms (25.8 MPG / 11.0 km/L)
City Driving:
Towing 50%:
Towing 80%: 10.5 L/100 kms (22.4 MPG)
95 Octane Petrol (Australia)
Country Driving:
Combo: x.x L/100 kms (xx MPG / x.x km/L)
City Driving:
Towing 50%:
Towing 100%: 11.7 L/100 kms (20.1 MPG)
All combined: 4404 km + 503 L = 11.4 L/100 kms (26.9 MPG / 8.8 km/L)
Best single run rec. by Foz's MFD 6.7 L/100 kms (35.1 MPG / 14.9 km/L) min. 100kms
Worst single run rec. by Foz's MFD 12.8 L/100 kms (18.4 MPG / 7.8 km/L) min. 100kms
Subaru quote...
Fuel Consumption Combined: 8.1 L/100km
Fuel Consumption Extra Urban: 6.8 L/100km
Fuel Consumption Urban: 10.2 L/100km
2014 2.5i CVT
Discussion Starter #9 (Edited)
After using the windscreen washer regularly, the warning light went out. So something started working again - perhaps the float came unstuck???🤷 The car had been sitting unused for months when I bought it so meehhhh... 🤷
Good job! Quick question, is there a second reservoir for rear washers? Or do they share the same water reservoir in the engine bay. My rear washer was working but not now even with a full tank?
2014 2.5i CVT
Discussion Starter #11 (Edited)
My Android phone runs v7.0 (with Samsung bloatware...). I ran Android software updates which included Bluetooth fixes and so far the Fozzy Bluetooth <=> Android phone hasn't dropped out again while streaming music... so far... 🤞🤞🤞
Update: dropped out again so forget Bluetooth and loaded up 32GB USB of music... plays perfectly now! ;)
2014 2.5i CVT
Discussion Starter #12
Good question @Boxa_2009! Short answer - just 1 reservoir. Longer answer... I just got my hands on some new washer fluid additive, added it to the front reservoir without considering there could be a rear reservoir too. Driving along and using the wipers and washer with new fluid, I suddenly thought about a rear reservoir, but after running the rear washer/wiper for 10-20 sec. I could see a few bubbles on the rear glass. Putting 2 and 2 together I got 3.5 = there is probably just 1 reservoir in your average SJ Foz ;)
2014 2.5i CVT
Discussion Starter #13 (Edited)
Towing Notes...
Towed a pod style camper (700 kg/1540 lbs) for 3000 kms/1860 miles. Fuel usage higher of course (log above), and engine temperatures increased. i.e. on a hot Australian summer day (35°C/95°F) the highest engine temp. I saw was 115°C/239°F
546619
Reactions: Kevin and Boxa_2009
2014 2.5i CVT
Discussion Starter #14 (Edited)
Off-roading Notes...
Did some light off-road / muddy tracks on the weekend. X-Mode worked a charm on 1 slippery gravel track - only noticed 1 wheel lock-up which was when I first engaged X-Mode (I was already on the steep and slippery track)
Getting feet wet and muddy...
546620
2014 2.5i CVT
Discussion Starter #16
2014 2.5i CVT
Discussion Starter #17
Miscellaneous / Small Stuff...
Ordered the following:
Phone Holder, mounts in CD Player slot, $A15
546688
546689
546690
Rear Cargo Mat, $AU30
546691
546692
2014 2.5i CVT
Discussion Starter #18
SJ AU 2014 key fob battery replacement... (short story made long...)
The battery in our spare key needed replacing - it was a simple process, I only needed a flat blade screwdriver, a small Phillips head screwdriver, and a new CR1620 battery...
Use a flat blade screwdriver to pry open the key fob at the gap in the corner shown...
547723
A few more gentle clicks to pull the tabs open and remove the cover and expose another cover...
547720
Remove the screws to expose the battery, hazar!
547721
New CR1620 installed and fob reassembled easily. Spare key fob now works again... hooray!
547722
1 - 18 of 18 Posts
