New poster here, I've scoured the site so far and can't find anything that i believe pertains to my case. I have a 2013 forester x limited, after replacing both front cv axles, hubs, rotors (went aftermarket drilled/slotted because my daily drive requires me to drive through mountains), and pads. After doing so, i have a pretty nasty vibration upon acceleration from around 25-65mph. Vibration isn't effected by engine rpm but it's directly effected by torque from acceleration. Jacked vehicle back up making sure everything was still tight and didnt find anything awry. Vehicle is my daily driver and i drive from gravel through mountains to 75mph interstate.
I have a 09xt and mine vibrates randomly when accelerating at hwy speeds. Mine has about 125k miles and I bought it used.
I've since replaced all struts and mounts with the assembled kyb units, and yeah it rides better but is still more bouncy than I'd expect. Not squishy bouncing like worn out shocks...but that's apparently another issue.
So yeah I had acceleration shake and the steering wheel was where I felt it most. After reading the few forester threads I could find about it, I decided to replace the axles with new oem ones. This seemed to get rid of most of the vibration but it still exists. $
I then removed the driveshaft and found the ujoints were stiff and notchy on both ends, so I bought a new oem driveshaft...that didn't change anything. $$
So yeah it still does it a little and mainly at highway speeds. Something I also noticed is after doing a few pulls it seems to get worse, like something is warming up and causing it.
There are no misfires as I've watched with a scanner. I've also installed new authentic ngk plugs and they didn't change anything.
I've also done a transmission flush with oem fluid, which didn't make any noticeable difference. Have also replaced the front and rear diff gear oil.
The only thing I haven't done is replace the front rotors or surface them. They are a little "warped" but nothing that causes a lot of brake shake.
I work at a dealership and deal with warped brakes on customer vehicles and Mine would be unnoticeable by most people.
So yeah time to research larger rotors, because I don't want to install another set of tiny rotors that are prone to overheating. These hogs aren't featherweights. 😀
