@LilHoag9 A wheel spacer might suffice or else, as you say, a different offset wheel. Coil-overs may be available for your model and as your car is 10 years old that might be a good swap (unless you've recently replaced the struts)
Yeah i'm looking into new coil over/struts just don't know what i'm looking for exactly. i just know the spot where the spring sits needs to be thinner or higher to prevent the rubbing on the front. if i can replace that in the front then i can get away with just a lift in the rear as well i believe, as long as i get spacer to recenter the tire... i think. been reading a lot, i need to get this work done asap before i ruin the tires.@LilHoag9 A wheel spacer might suffice or else, as you say, a different offset wheel. Coil-overs may be available for your model and as your car is 10 years old that might be a good swap (unless you've recently replaced the struts)
This is an answer I'm looking for, thank you. I am currently on stock rims and was unsure what size offset would be safe as I am not a fan of spacers either, I have heard too many stories about them. the rims offset and the ADF 1" in front 1.5" in back i think will work great.If you are currently using the stock rims with +48 offset, then I would recommend finding a set of rims with +40 to +42 offset. I am not the biggest fan of spacers.
