Getting loud grinding sounds from front end/axles/...wheel hubs maybe. After my 1st time clutch change of a fwd vehicle. Been servicing my own & friends cars for over 35 years.
Any help appreciated !
The grinding is same in neutral. The cv's feel tight & the are no thud's when stoping or starting forward or reverse. I had replaced the right bearing only... that was some work, had to hammer & pry it out...rusted right in place but cleaned it up good, coated w/ anti-seize & bolted as per torch stats.You might want to get it on a lift and see if you can find the culprit and/or make it misbehave in the air under power.
A grinding bearing should make some noise even when manually rotated and/or there is a lot of play.
Sounds like a CV joint, maybe on the left side, but it could also be any bearing in the drivetrain front end, as any of these tend to make more noise with increased speed of rotation.
What happens when you are driving along with the grinding noise and you put in the clutch? Shift into neutral? Any change?
Thanks for your input, it helps to know that someone else who knows mechanics is suggesting the same ideas as my own thoughts. For integrity sake I'll let you know how things turn out my friend.Anything is possible, but you are in a better position to evaluate what you did than I am.
There are bearings on the transmission end of the shafts as well.. not as common perhaps.
Hopefully the lift exercise will be revealing, and if it were me, I'd try to isolate the problem rather than throw parts at a symptom.
At this point all I can say is good luck, so...
Good Luck!
