1 - 8 of 8 Posts
2001 Forester
Forester X AT with Type A (manual control) climate control knobs (pretty much a no-frills model).
I'm not a mechanic (but a retired engineer) and this puzzles me. After a year of flawless operation, the fan abruptly stopped running at all on speeds 1,2,or 3. Speed 4 is fine and full blast! The heat, AC, and inside/outside air seem to be normal at speed 4. (Actually, the AC red pilot still turns on/off for speeds 1/2/3.)
This thread in 2011[post 2] had a service diagram for 2003 models. Is that still valid for 2012 models?
https://www.subaruforester.org/threads/blower-motor-melts-wires-off.95818/#post-1043553
Not much in the 2012 owner's manual on wiring or fuses. Any help appreciated.
2001 Forester
Thank you. That is a great help.
Is the "resistor module" AC-01730 a replaceable part? Are those spade connectors (and their four color-coded wires) shown in the diagram above? Why is it labeled 'B27' there (excuse the novice here)?
@mygfscar B27 is the connector, look on the bottom of the wiring diagram.
This thread might also be helpful to you.
2001 Forester
Good link for the procedure. Thanks.
Still, I'll admit a little confusion. B27 has the resistor symbols. Isn't this where the bad resistor might be?
[Or, I suppose, possibly a bad wire coming off connector 4 - the BOr wire?]
@mygfscar B27 is the connector that plugs into the resistor unit. It's shown that way on the wiring diagram as the lead wires are easier to draw on the schematic.
527429
► Disclaimer - always verify any information you read on the internet, especially if you're going to spend money on parts!
2009 Legacy
What @2.5x_sleeper is alluding to is that the entire module needs to be replaced.
Sure, internally one of those resistors may just be open but you can't get into it to replace it. If you follow the functionality of the switch, in position 4 it bridges that resistor pack. If you switch any other position it switches more resistance in series with the fan, causing it to turn slower.
2001 Forester
Discussion Starter #8
Got it , I think. The connector is numbered, the resistor unit is named. They occupy almost the same spot on the diagram.
1 - 8 of 8 Posts
