Hi there, have a 600km old 2011 FXT and I have found on all occasions that the oil level on the dipstick after checking when the car is hot (after letting it sit for 1 min on flat surface) is running at about 1cm higher than the notch. This seems quite high, as if the car has been overfilled from the factory.
Is this done on purpose cause the car might burn oil in its early km's?
So far I havent seen it go down at all, over the first 600, so should I take it back to dealership and get them to drop some oil out of it?
What damage can overfilling do, or this amount of overfilling?
