Thanks for your site. I am burning oil. Cant find leak. So....I want to put in a gauge array for Oil pressure, Temperature, and maybe voltage. Any suggestions for a nice looking on dash array?
2017 2.5i Fozy CVT
I guess it depends on year... I see CVT,OIL,COOLANT temps , and VLTs on my17.... just parameters I have selected... many others.
@Rob2011Forester on plug in OBD2 devices, you're using the sensors that the ECM - engine control module uses. If there's no sensor, for what you want to monitor, there's no data to monitor.
You can install your own discrete gauges, but that will require some fabrication for the cabin installation & you'll have to install your owns sensors (senders).
