1 - 7 of 7 Posts
2011 forester x touring
Just wanted to get a feel for what you guys are using for a jack for a lifted Subaru. I also wanted to know what you guys carry for recovery. Any help would be appreciated.
I use the OEM jack and a couple of 4x2s if necessary. Minimum gear is tire pump, snatch strap and rated shackles. Anything else depends on the type of tracks you intend to travel?
I have purchased a few tow straps and a recovery board. I also picked up a new scissor jack I found off of OfferUp that I think will work perfectly for a lifted forester.
529392
2016 Forester 2.5i 6mt
Take a wider piece of plywood to put under the jack & or two by fours , even a high lift jack I’ve had to use a piece of plywood, I’ve had to sacrifice the plywood before in mud, with a Scout
Do any of you have a skid plate or box for your rear diff? I have Primitive's box, and it's touted as a jack point. Nothing they sell is underbuilt, so I trust the claim, but has anyone here used it that way? I'm being swayed by some folks who are bottle jack fans, and I'm on the fence.
529955
2018 Premium 2.5i 6M
Agreed -- wood for use in the snow where I live, in addition to helping with the lift on my car.
I keep the Subaru-supplied tow "hook", an associated D-ring, and a tow strap in the cargo cubbie holes (instead of having to dig into the spare-tire compartment).
1 - 7 of 7 Posts
