I’m new to Subarus and the forum. I could use some advice. Bought the vehicle last weekend with 95k mikes after paying my mechanic to do a pre purchase inspection. Checked brakes, frame, body, fluids, ran codes and test drive it among other things. Gave it the thumbs up.
I filled the tank and began enjoying my new purchase. Had the state vehicle/emissions test done (PA) and an oil change. No problems passing emissions testing. Everything seemed fine until I realized there is a mpg indicator on the dash. States 12mpg. I start poking around under the hood and find the coolant bottle is all but dry, there was a small amount of gunk on the bottom of radiator cap, the sound proofing under the hood is damp with what seems like oil or antifreeze (can’t tell), and there’s worm style hose clamps on both radiator hoses, which leads me to believe the hoses may have blown off at one time recently. I haven't had a scanner on it since the pre purchase inspection so don’t know if any codes but there is not a check engine light and the coolant lite stays blue for a few minutes while it warms up then goes out. Hasn’t gone red. I did do some driving in 50 degree weather and let it idle while parked and the fans never kicked on, maybe not hot enough? The upper and lower radiator hoses are firm and hot at operating temp and I have heat. Engine sounds fine to me and power doesn’t seem bad but it’s my first time owning a 4cyl.
I know just enough about cars to get into trouble. I’m concerned I may have bought a major repair bill. Any help/advice would be appreciated.
