In 2020 I found out I needed new brake rotors and pads. I had them replaced with StopTech rotors recommended by a local and highly-recommended Subaru mechanic (not a Subaru service center).
About a year later (~8,000 miles) the car developed some shuddering when braking at highway speeds. It came and went for a while but then became more common. I had the Subaru mechanic check it out and they couldn't find anything wrong. Got the tires balanced, rotated, but didn't do much to help things. An OBDII scanner was throwing off a C0074 error, but no problems were found with the ABS system.
A few months ago a grinding noise started with the rear brakes. It was bad -- people stared when I was driving by. I took it in and I had a stuck pin, which required the replacement of the rear rotors and brakes. At the same time, they cleaned the ABS sensors, which seemed to fix things regarding the shuddering.
A few weeks ago the shuddering started up again. I took it to a Subaru service center and they noted significant, uneven wear on the front rotors and recommend I replace the front rotors and brakes. These had less than 14,000 miles on them.
Anyways, any idea what could be causing these brake/rotor issues? Have I just been unlucky? The car sits for most of the week and is only used on weekends for city driving; it probably only gets significant highway usage once every two or three months.
