2011 2.5x Limited
Both power outlets - under the armrest and center console - are dead. I'm assuming there is a fuse for both; can someone tell me which one it is?
Thanks,
Mark
There is a fuse panel diagram in your owners manual. There should also be a label diagram on the back of the cover that you remove to access the fuse panel.
2011 2.5x Limited
Honestly don't know if there's a diagram on the panel. Found the problem last night, thought it might be the usb charger. Confirmed it was the 120v outlets after trying another that I know was working. I'll open the panel after work and take a look.
