1 - 2 of 2 Posts
Will the transmission from a 2012 Subaru Forester fit my 2010 Forester They’re both 2.5 automatics My 2010 has 198,000 miles on it starting to have some transmission problems I can buy a wrecked 2012 with 78,000 miles no engine for $300 hoping the transmission will interchange
2008 Subaru Forester X (SH)
Not sure if the 2012 still used a 4eat trans. Maybe compare the transmission codes - there’s a label on the right side of the transmission (left side looking into the engine bay). For example the one on my 2008 non turbo 2.5l (ej253) is TZ1B8LCZAA this covers a range of years. (2008-2010 I think). If the codes are a perfect match you should be all good. A “B” instead of a “C” in the code above indicates it’s a turbo 2.5 so will have different ratios.
1 - 2 of 2 Posts
