Warning lights with no issues....
I have a 2010 Forester pzev with 152,000 and I keep getting the check engine light along with the blinking cruise, anti skid and the ABS light. If I let it sit for a couple days they go out for maybe 150 miles or so then pop back on. I’ve replaced the gas cap and that didn’t solve it. Took it to some parts stores and one said it was vapor lock from the gas cap and another said it was the cat converter. Usually if it’s a cat you lose performance and it gets red hot if it’s plugged.....it has an older battery but fires up relatively easily...could that be an issue?
