I will try to be brief:
2010 Forester 2.5L non turbo has a stumble at takeoff from idle.
Took the opportunity to put in crankshaft sensor, camshaft sensor,
both O2 sensors, cleaned MAF, new air filter. Reasonable prices but
NO improvements.
Developed an intermittent misfire on cylinder #1 ( 3 times ). I was not certain if
this was a cause or effect of the stumbling.
I had hesitated in checking the spark plugs, since I had replaced the plugs
with NGK Iridium plugs and only had 35K on them. See attached photo.
Since the #1 plug is easy to get to, I put a new plug in cylinder #1
and voila, problem solved, idle is smooth and no hesitation now.
My question(s): any ideas why the Iridium plug deteriorated so soon?
Do the discolorations on the plug hint any any other problem?
Would you expect the other 3 plugs need to be replaced? I know that is a
trivial question, but I don't drive the car but about 10 miles a day, and
at 155K miles, do I want to open up trouble by changing the other 3 plugs.
I am thinking of inspecting cylinder #3 which isn't too difficult to get to.
I hesitate because the plug on cylinder #1 was a bit tight coming out and
the others aren't as easy to get to.
Comments are welcome.
TX
NO improvements.
TX
