2002 forester
2010 45 k miles and new coil pack. I'm getting a cylinder misfire code... The cruise keeps turning on and the traction control keeps turning off on its own. All started at same time. Has new coil pack. Running rough when cold but that resolves when it warms up. Whats going on with my ride. Thanks in advance!
Sent from my LML211BL using Tapatalk
non-subaru
The traction control and cruise lights you can ignore. They turn on when it throws a code and the Check Engine Light (CEL) is on.
It the misfire on the same cylinder or random?
If on the same, see if moving the offending coil pack to another cylinder moves the code as well.
2002 forester
So just to respond to this so people can use it in the future I sanded the battery terminals and it resolved the issue. Thanks for the help
