801 - 806 of 806 Posts
2011 Forester XT 4eat
Get new nuts for the ends. That's all you'll need. I installed my bars just after Galager did.
So, here's my current suspension setup:
Swift Sport springs (~1.6" drop) w/ Tein spring silencers
Stock struts
19mm STi rear sway bar with Energy Suspension Black Poly bushings + RalliTek endlinks
Stock front sway bar with Energy Suspension Black Poly bushings+MOOG endlinks
KYB front strut mounts (because I f*cked up one of my studs and had to replace them)
Whiteline Roll Center Adjustment Kit
Perrin Steering Dampener lockout
Cusco Front Lower Arm Bars
**Upcoming stuff: Energy suspension control arm bushings front and rear. My rubber is completely SHOT. However, since this XT has been a Central TX car it's whole life, there's zero rust, so that's pretty pleasant to wrench on.
Eventually, I'll need/want new struts, too.
This is a daily driver, and she has 156,000 miles, so I'm mainly refreshing the driving feel (she'll never, ever, be tracked). I love a comfortable, responsive wagon that is a little bit of a sleeper. Stock wheels, and all-season tires.
529025
How you like those bars? Between those and the Bilsteins I’m in heaven.
I put them on at the same time as the springs, and the effect was dramatic ( I had the rear sway bar, bushings, and endlinks already).
the Cusco bars made the front end steering more of a "yaw" than a "roll" situation. I'm excited about the LCA bushings, because as I strengthened the other parts of my suspension, the beatass rubber in the LCAs is making a horrid clunking noise. Can't wait to get rid of those mushy cracked bushings.
I recommend the Whiteline RCA kit, even though it's a little pricey... I can tell the grip at the tires is better with the geometry in the right place. No more singing around corners at low speed.
2011 Forester
Hi! I’m new around here...
Here’s my SH Forester on Fortune Auto 500 coilovers with 8k springs. It’s almost a 4” drop. The car is a 2011 NA with the 5M.
I inherited it from the wife when she got a new car. The 2015 Transit Connect parked behind the Forester is mine also.
529706
