Same here... photos post laterI use the long one. Doesn't fit perfect but it works.
I had the same problem (I started a thread about it sometime last August, I think), but it turns out that a sort of intermediate position has worked well, using the long claw.I have a 2010 Forester and want to mount my new Yakima railgrab kit. However it seems the small claw is just to small, but the large claw seems to big.
Which claw did you use with your 2009/10?
If Yakima thought it worked well enough for the 09 then they will think it works well enough for the 10 most likely. I hope they come out with a new "medium" claw, but not holding my breath. I'll just make it work with the large claw for now.I had the same problem (I started a thread about it sometime last August, I think), but it turns out that a sort of intermediate position has worked well, using the long claw.
I actually complained to Yakima about this; they said they're working on testing the 2010 year, but it should work as-is since it "works" on the 2009 model. They're right, sort of -- it doesn't look right, but it's been very stable and secure for the months I've been using it...
