When ign key is removed, drivers door open. Key left in ign alarm goes off, can"t lock. Read sticking switch,not easy to change. Can just cut wire to disable. Will this work with out any problems. Also witch wire to cut? thanks
@paravet I see this is your first forum post, so welcome to the forum from Oregon! :biggrin:
Take a look at this thread to see if it could be causing your problem: :confused:
Ignition key problem - micro switch workaround
Also...
