Noticed a smell while driving home today. When sitting still for more than about 20 seconds, there'd be a burning smell in the cabin. I was driving through a pretty industrial area at the time, so figured it was just a coincidence. Parked in my garage and the smell was overwhelming though. Popped open the hood and saw what looked like oil overflowing from the filler cap - photos attached. Checked dipstick, and oil is about 2/3 the way between the low and high marks (closer to high than low).
A few minutes before noticing the smell, I had floored it up an on-ramp. Possibly some kind of oil pressure or PCV issue? I did a quick search of the forum and didn't see anything related, so apologies if this has been covered before.
Thanks
Discussion Starter · #2 ·
Unrelated to the problem, just want to clarify: Car has no known head gasket issues (133k miles), but does burn about 1 quart of oil every 3000 miles. The dipstick reading is right where I'd expect it to be at this point between oil changes.
Alright, one more update. Started the car and took the filler cap off. There's a good amount of air/exhaust puffing out. Tried the same thing with our other car, a turbocharged VW, and there was a huge difference. This normal?
Hard to say. Just replace the PVC valve and insure there is a rubber o ring under the cap.
Replaced the valve, the one that was in there was definitely bad. However, the vacuum line was really brittle and I think it might've developed a small crack or failed to seal when I put it back on. Car has much worse throttle response at low speeds now. Planning to pick one of these up on my way home tonight.
