Hi,
This weekend I installed an 8" powered sub into the 09. The HU's 20-pin connector wire colours did not match my research. Findings are below and in pictures. I found an existing, water tight, rubber body plug to pass the power wire from the interior to the wheel well, into the engine bay. This body plug was a nice find as it has room for future 'holes', included in the pictures. I also used flex-tube to route and protect all the wires - although it's all hidden, I like how clean everything turned out.
I've posted too many pictures here (link removed - pictures go bye bye). The captions hopefully provide useful details and info. If not, let me know. I didn't include pictures of the final in-dash wire bundle - as you can imagine, it's a bundle of wires - properly connected, of course.
Oh yeah! and it sounds great! Not a boom boom dance club, but it adds some nice bottom end. :discomonkey:
Cheers,
G
Colours of a 2009 Forester 20-pin audio connector: The connector has two rows of 9 smaller pins, plus two larger pins on the far left and right sides. I've numbered the larger pins 10 & 20. I'll photoshop the wire numbers in the pictures when I get a chance. For now, the captions point back to here for the correct numbering and colours.
TOP Row
10 - Black - Ground
1 - Violet/Silver Dots - Illum. with headlights
2 - Black/White/Silver Dots - Dimmer
3 - Yellow/Red - Ign Switched 12V accessory
4 - Lime Green/Red - Steering Wheel Control (-)
5 - Red/Yellow (LR -) [paired w/ 6]
6 - White/Black (LR +)
7 - Brown/White (LF -) [paired w/ 8]
8 - Brown (LF +)
9 - Yellow/Black - Antenna Booster
Bottom Row
11 - Blue (CAN bus) [paired w/ 12]
12 - Pink (CAN bus)
13 - empty
14 - Yellow - Steering wheel Control (+)
15 - Grey/Red (RR -) [paired w/ 16]
16 - Grey (RR +)
17 - Blue/Yellow (RF -) [paired w/ 17]
18 - Blue/White (RF +)
19 - empty
20 - Blue/Red/Silver Dots - Constant 12V +
Other Research/Sources of info:
1) I installed the Kenwood KSC-SW10, purchased from Car Audio Stereo - Car Subwoofers - Car Amplifiers and Speakers
Owners Manual: PDF
2) Search for 'Blue' wire info here:
SF.org link 1
SF.org link 2
3) You can also optionally install what's called a line-level converter. It's usually used in car audio where the deck only has speaker outputs. The converter lets the headunit play the speakers normally while giving you an RCA signal to feed some amps.
Google images
Google Search
4) 20 pin connector pin out:
NASIOC link 1
NASIOC link 2
5)
Wiring Diagram :2009 Subaru Forester
Battery BLUE/RED (+)
Accessory YELLOW/RED (+)
Ground BLACK (-)
Illumination VIOLET (+)
Dimmer BLACK/WHITE (-)
Power Antenna YELLOW/BLACK (+)
LF Speaker (+) BROWN
LF Speaker (-) BROWN/WHITE
RF Speaker (+) BLUE/WHITE
RF Speaker (-) BLUE/YELLOW
LR Speaker (+) WHITE/BLACK
LR Speaker (-) RED/YELLOW
RR Speaker (+) GRAY
RR Speaker (-) GRAY/RED
Cheers,
G
TOP Row
10 - Black - Ground
8 - Brown (LF +)
Bottom Row
12 - Pink (CAN bus)
13 - empty
16 - Grey (RR +)
19 - empty
Owners Manual: PDF
SF.org link 1
SF.org link 2
Google images
Google Search
NASIOC link 1
NASIOC link 2
5)
Ground BLACK (-)
RR Speaker (+) GRAY
