1 - 11 of 11 Posts
2008 Forester
hey everyone. after leaving my forester for 4 weeks without driving apparently one of my mufflers stopped working. the other side is fine. could it be some dirts got into the muffler and dried? was working fine before.
2012 Forester X Auto
That was my question as well.. If it's that there is no apparent exhaust coming out of it, it may well be blocked.
That would take a lot of dirt. Were you wading the car through a mud bog? Otherwise unlikely.
Rodents on the other hand could have built condos in your exhaust system in less time.
Since the dual exhaust is actually a single exhaust with two outlets, it won't take much blockage for the exhaust to take the easy open path.
2008 Forester
thanks everyone. what chemical should i use to clean the interior of that particular muffler? i dont see anything blocking tha main passage when i see it from behind. will take it out and try to clean it when i get some spare time.
2008 Forester
How did you come to the conclusion that one isn't working?
there is absolutely nothing coming out from 1 of the mufflers. was working just fine before. i drive mostly in remote places where water and mud are constant.
2010 Forester
You have a manifold on each head, since the car runs you can rule them out as an issue. Your problem must be after where they meet under the car. Trace that pipe from the muffler forward. On my 2010 that's a very short section.
@Bovka I see you're located in Asia, Mongolia & you listed your model year as 2008, which in the States... USDM would be a 2009. No dual exhaust in 2008 USDM Foresters.
Looking at the exhaust diagram below, not a whole lot there, other than the muffler. Any chance something... insects or rodents got in there & built a nest?
Reactions: Bovka and SuperRu
2008 Forester
@2.5x_sleeper thanks for your input. mine is japanese model . 3rd generation japanese models started in 2008 until 2013. so mine is 2008 model SH5 2.0L engine :D thanks again everyone i will have a look at it today and see what the story is.
2008 Forester
Discussion Starter · #9 ·
ok guys just finished checking and one of the 2 pipe lines that goes seperate ways from the main pipe is not blowing. tried blocking the working(left side) pipe and brought RPM high but didnt fix the issue. have to disassemble the rear pipe and see when i get a chance. by the way what is inside the chamber in the middle?
2010 Forester Premium X AT
I've had the baffles inside the muffler collapse and block it. I would assume the same is inside the mid pipe resonator. Maybe all you need is a new resonator.
2008 Forester
Discussion Starter · #11 ·
ok guys i have found and fixed the issue. it was baffles inside the mufflers blocked the mid section and i blew it out and all good now. hair like stuff :d thanks everyone.
1 - 11 of 11 Posts
