1 - 10 of 10 Posts
2009 forester. I swapped out the engine which had failed on this car for a jdm engine.
following the instructions from the dealership service dept., I used wiring harness and intake manifold from the old engine. when I attempt to start the new engine, dash lights up as it should, but all I get is a series of electrical clicking sounds on the right side of the engine front. no starter sounds.
Hym
2009 Forester 2.0 XS
Is it 2.0 XS? 2.0 XT turbo? which version? AFAIK it is not trivial to connect all plugs to the ECM. BTW, are you using the old ECM or the new one? I think everything should be swapped. But I am no expert in no way. Some others hopefull will chime in.
2003 EJ20K Forester
Starter systems are really unintelligent and should work with what you've done. This makes me think its a battery or battery connection problem. A loose connection will draw the few dozen amps it takes to run the lights, fans, etc, but the 600A peak starter draw browns the system out. Tighten the battery terminals and check the battery voltage (on the clamps, not the posts) while trying to crank
On both the old engine and the one I installed, ground straps from body to engine were shot. I also located the starter ground cable on the top bolt for the engine/bellhousing, would any of that make a difference? I now have the battery charging.
2004 forester sti
Of course it would , No connection =No Starty Party
2003 EJ20K Forester
I'm not certain what factory is for your specific vehicle, but a very common choice is beneath a bolt/nut that holds the starter to the bellhousing/engine directly to the battery.
new ground straps for both sides of the engine, new battery, she started right up. Many thanks for the input and guidance, far better than the " my guys only make money when they are working on cars" that I got from the assistant service manager t the subaru dearship.
James
2004 FXT 4EAT
I did some major engine work on my 2009 XT last year and had all sorts of problems with it not wanting to start.
Some things I discovered in that process: if you don't have the plug that goes to the Intake harness plugged in properly: no start!
There's a ground wire on the fuel-rail (on the 2.5 XT).If that one isn't good and tight: No start...
And yes: A fully charged battery should help. Make sure the voltage isn't dropping too much when you're trying to start it. If the voltage drops below 10V while you're trying to start the engine, you should have the battery tested.
Discussion Starter · #10 ·
Starting right up and idling well is not the same as running well...on a test drive, I noticed extra engine noise and some vibration. I got an engine code: P0028, which concerns the ECU. Can I reset this?
Hymodyne
1 - 10 of 10 Posts
