The principle is the same. Bolt location would differ long with bend angles and whether you cut your plate to cover everything (mine) or just the stuff in the middle (oil pan).
If you look under your FXT you will see the 3 or 4 bolt mounting points. The rear 1 or 2 will be on the main structural piece directly between the front wheels.
I will be able to look at a friends 07 FXT in late may. I can tell you exactly what is needed.
Oh, I fixed the scratch (no pics). I used 220 sand paper. wiped it clean with water. 2 squirts from the spray can and done. During my warm weather oil changes I will do a complete repaint.
I really like the look. This shiny piece of metal no longer distracts you from the overall beauty that is my 09 FXT. The matte black matches my grille perfectly (came from the same can)
