2009 Subaru Forester X Touring
I have a 2009 automatic forester with just under 300,000 Kms on the clock.
I just started noticing that when I decelerate, there is a constant squeak\chirp sound. the noise is somewhat broken, not like a continuous squeal that you would get from a belt. if I had to guess I would say it sounds like a bearing going bad.
I don't think its a wheel bearing as the sound doesn't change when turning one way or the other, and is only on deceleration.
I'm not sure if this would cause the issue, but I recently started regularly using the manual sport-shift or whatever Subaru calls it (I call it tip-tronic) and allowing the car to decelerate in 3rd or 2nd instead of using the brakes.
also of note is that I just changed out the gear selection switch on the side of the transmission, and it was somewhat traumatic lol.
After beating on the spring pin with a drift and progressively bigger hammers trying to drive it out I ended up just drilling it out and replacing it.
to get the arm that connects to the selector cable off of the shaft that goes into the transmission, I Initially pried on it a with a large pry bar which did cause the shaft to deflect. maybe tried this a dozen or so times while also hammering on the arm to try and vibrate it free.
In the end I had to purchase a small 3" pully puller that I had to modify the arms on so they would fit behind the flange on the gear selector arm to pull it off the shaft.
(not my picture)
any chance I could have damaged something in the transmission from this?
also the noise goes away when the car reaches about 10km\h while decelerating
I was planning on replacing the u-joints in the driveshaft soon as I found that they have some rotational slop, could this be the output shaft bearing going bad from worn out u-joints?
I don't think its the carrier bearing would make noise only on deceleration would it?
I gave it a try yesterday. the best that I could tell is that it does go away when in neutral. its not like a constant noise while decelerating, it sort of comes and goes.
I think Im gonna pull the driveshaft this weekend and see if I can find anything wrong. i gotta order and install new u-joints for it soon, so It would be good to know if I need to replace the output shaft bearings so I can do it all at the same time
also wondering if maybe its just something to do with the brakes, perhaps the dust shield or something.
2005 Subaru Forester XT
on my older XT, i had a similar sounding issue, although its a bit of a random problem that i wouldn't expect on a newer model...
The back plate, which the handbrake shoes pivot off, was rusted and rubbing on the disk. the dust/rain sheild is attached to this part and there was visible rubbing with the disk off, but not a feeling of friction with the wheel off. didnt seem to cause any problems but was annoying, chirpy and only audible at around 15mph and below.
i just filed away the offending material. i assume the plate will bend or rust again and the noise will return....
