Yesterday my mom’s car gave a p0028 and p0026 code. I read those were usually caused by low oil. I checked and it was VERY low. Nothing showing up on the dipstick. 3 quarts later and it showed just above the low line. I thought it was a crazy amount to have to add but I drove it around, no smoke or oddness. It had been 8000 miles since the last oil change. I cleared the code and told her we could do an oil change tomorrow.
This morning she called because the car is stalling. It is stalling in a very peculiar way. When you roll to a stop, the engine idles too low and stalls. It did stall me once while coasting at 30mph. Has no trouble starting right back up, all the it idles very low for maybe a second. She brought it over and I changed the oil (only 4 quarts came out)
It seems to idle just fine. I tried doing the idle relearn just in case and no dice. Battery tested fine. Has anyone experienced this before?
Below are videos of what is happening.
While driving
https://youtu.be/k7lFNwj7ae8
On ignition
https://youtu.be/J43kAd7THxs
While driving
On ignition
