2010 Forester LTD
Took this picture during changing fog bulbs.
cool thanks for sharing, I wish the horns had more "oumph" I find they are bit too high pitched.
2018 ForesterXT Touring..
progeek, just wondering is the bumper easy to remove? I know how to remove the pins on the top and bottom. I'm more concerned about removing the last 2 holding the front end at the sides. I want to put a bug screen on the radiator, and run the block heater cord through the bottom(instead of resting it on the top).
2010 Forester LTD
it's pretty easy to remove move the bumper though. it took me 30 mins to take everything off, but longer to put it back cuz I need to fit everything as where they were. The side pins are easy to remove, use a tooth picker to push the inner button in, then you can just pull the entire screw out.
I wonder how much does it cost there plastic screws tho, anyone knows?
