'03 XS
Hello all, I have an '08 Forester XT
A couple weeks ago I got a flashing check engine light and pulled the codes and it was cylinder 4 misfire.
We swapped the coil to cylinder 2 and the misfire followed.
We replaced all the plugs and the coil.
The car ran great for 1 day, now has no power and is obviously misfiring pretty bad. Very rough Idle
Now I have 3 different codes
cylinder 1 misfire
PFFFF
PFFFE
Anyone have a clue where to look next?
'03 XS
Thanks, the plugs looked fine.
Cylinder 1 coil was very hard to get off as the boot seemed stuck to the plug.
2017 2.5i Fozy CVT
A google search for" subaru pffff" yields some pertinent data on other suby forums.
Ever adjusted valves? Oil burner or not? Miles on ODO?
'03 XS
It had a burnt valve @ 98k
The previous owner fixed that and all related parts
now at 137k and uses no oil
Yes I've been reading up thanks.
I think the coil might be have gotten damaged when trying to get it off the plug
'03 XS
UPDATE
I changed out the coil pack and all is well.
The coil boot was stuck on the plug and I must have damaged it when removing it.
I could not tell that the boot was damaged. It was fully seated when I took it off.
2017 2.5i Fozy CVT
It is easy to damage anything. When I changed my plugs last, I damaged/cracked an insulator/ceramic portion when I was monkeying around trying to get the right dangle angle for install.
Had to swap it out for the misfire to go away.
Dielectric grease on the boots helps.
