So on our 2008 WRX I had to replace both Banjo/Filters and the passenger side inner timing cover. I got it all back together and started the car and there is a mystery oil look dripping from the passenger side timing cover at the bottom on the seam. I thought it was that big O ring that goes on the cover of the intake cam gear. I pulled both outer timing covers and started the engine. It doesn't look like it's coming from those O rings. I took pictures. You can see the oil to the right of the passenger side cam gears. I'm stuck on where the leak is and need ideas on how to locate the leak.
