So, I have read all the posts I could find but still have some questions:
1) Are the stock 2008+ STi sway bars 20mm front and rear?
2) Are the stock 2009 Forester sway bars 16+/- mm?
3) Will the stock 2008+ STi sway bars (front and rear) bolt right up to the 2009 Forester?
I am planning on using the rear STi sway bar mounts and upgrading end links front and rear to the Kartboy units.
Thanks
2010 X Premium 5 Spd
I can only answer parts of your question
08+ STI Rear sway bar is 18mm and is a direct bolt on to the 09+ forester
09+ Forester rear bar is 16mm
I upgraded my rear bar to the sti bar and it did make a noticible difference. I also have a set of swift spring that I am gong to be putting in. If I wasn't going to put the swifts in I would want to put bigger bars f & R as the sti bar alone does not get rid of enough of the bad habits of the stock setup.
Marc
