2008 Forester
Recently started noticing that something is not right at our front passenger wheel when the car starts to get over 40mph. Feels like a vibration or something may be loose. Today had the tires rotated and balanced - and that actually made it a little worse. Tires are all good. Put car up on jack and tried to push/pull wheel from bottom to see if there was any movement, but it did not seem to move. It does need new front brakes which will go on in about a week. What would the most likely culprit be to look for that would produce this symptom? Tks.
Probably wheeel bearing. Usually the rear's cause problem. Fronts can fail also
Very rare to feel any movement from that test.
I have found a great way to check bearings is to find some S bends and by traveling at a reasonable pace the weighted side can make the noise change if the bearing is at fault. Most often it gets louder - but - in the case of my son's SH which had a bad left-front bearing the noise stayed the same when weighted but disappeared when unweighted.
2008 Forester
There are no sounds coming from the wheel - just a subtle but noticeable vibration from the passenger front wheel once certain speeds are reached. We did replace the rear bearings last year.
