JDM Forester XT 2008 EJ205
I wonder if someone can help, if these control arms are compatible with a forester SH 2008-2013 TRC1058 Subaru Standard Lower Control Arm Assembly Kit
On a different site it shows that they are compatible but there's no mention of the Forester SH model on the SuperPro website..... SuperPro Suspension Front Lower Control Arm Assembly Kit for Subaru | TRC1058
I asked SuperPro europe and here is the answer:
''Thank you for your email, TRC1058 is not compatible with Subaru Forester SH XT. Check Subaru parts catalogue and Impreza & Legacy has different OEM part number, now this could be the bushes are different hardness and arms are the same, but is also could mean they run a different track.''
Just from looking at the pics it looks like the arms are the same.....so it could it be that the bushes are just a different harndess?
Discussion Starter · #2 ·
2011 Subaru Forester
Maybe you should contact the seller to see if they have any info, and why they did not list the Forester. According to RockAuto 11-14 Imprezas use the same front control arms as the 2009-13 Forester, and the 2014 WRX. Maybe use your Vin at a Subaru Parts website and find the control arms for yours and see what other Subaru models use the same part.
Discussion Starter · #4 · (Edited)
I'm waiting for a response from SuperPro but I think they might fit as from Subaru Parts I get this for the Forester SH
Part Number: 20202SC014
Supersession(s): 20202SC010; 20202SC011; 20202SC012; 20202SC013
And from looking around the Impreza G4 2011-2016 has the following part numbers for the control arm: 20202SC000 20202SC002 20202SC010, 20202SC011 20202SC012 20202SC013, 512-50399R 512-50400L CMS801051
So I'm assuming it's a fit then?
And from the JDM Subaru Parts website the part number I'm getting for my Vin is also compatible with Subaru Impreza WRX STI GRE GVE , is GRE the same as the GR listed on the Superpro Europe as compatible ?
The car is a JDM the arms are european and the impreza models I'm comparing are USDM ......sort this mess out then ....
