1 - 8 of 8 Posts
2007 Subaru Forester
I have owned a 2007 Forester NON Turbo for about a year now. It has 80K miles on it and is consuming just about a quart of 5W30 oil every 1,000 miles. So far, I have performed an engine flush and replaced the PCV valve and it is still consuming about the same amount of oil. I drive mostly on highway daily at about 75-80mph at about 3200 RPMs. To my understanding, these motors DO consume oil, but not at the rate I am experiencing. I am the second owner and I am guessing the previous owner didn't drive this vehicle daily. I have called the dealer to find out the process of elimination to oil consumption before having to rebuild the motor and I am now at the conclusion that it needs rebuilt. Is there something I am missing? I haven't heard of anyone having to do a rebuild this early without driving being rough on the motor. If I do have to rebuild or replace the motor, I have had thoughts of adding a turbo or swapping for the turbo EJ25 or maybe even the EJ255 STI. The reason I want a turbo is to be able to climb the mountains in Arizona without excessive abuse on my engine. Any and all suggestions would help and It'd be greatly appreciated. I do have a lot of mechanical background but this is my first Subaru and I would like to keep it for a long time. Thank you!
For the first part of the year I ran 10W30 and there wasn’t much difference in oil consumption
2010 Forester
First thing to check is head gaskets, they are known to fail.
Second thing is to ditch the dealer and find a local independent Subaru shop.
No head gasket leak and I never took it to the dealer. I do my own work and have friends who work at the dealer that explained their process of elimination. I will try running 10W40 and see how that goes. I am just needing info for when I do need to rebuild or replace the motor.
2013 crosstrek, Forester+
I would run basic diagnostics such as compression test and then leak down test. I suspect rings are leaking which may happen on these engine if not broken in properly. Heavier oil may help with low oil pressure but may only help a bit with consumption. I would try adding 20% Marvel Mystery Oil with fresh oil change and run it hard for 1000 miles to see what happens but only if the leak down test is not definitive. Find a Subaru shop to look for wrecked donor if all else fails. Best of luck.
1 - 8 of 8 Posts
