2007 Forester 2.5 auto
Can some one direct me to where the flasher/turn signal relay is located on a 2007 Forester? I have found on these postings locations for several year models but none for a 2007.
Neither my turn signals or four way flashers work.
Thanks
@lzthunder I see this is your first forum post, so welcome to the forum from Oregon! :biggrin:
The SG wiring, '03-'05 & '06-'08, is nearly identical, so you could use the earlier SG forum posts to find the turn signal & hazard unit. With that said, the diagram below is specifically for the '06-'08. :wink:
also...
