1 - 2 of 2 Posts
I have a 06 forester ej 2.5l. I was looking at getting a motor from the junkyard but was concerned that not all ej25s would fit from different models of subarus? The car I was pulling it out of is a 09 legacy ej25 2.5
I'm not sure what years/models would fit, I read about the variable valve system changing in 2006ish?
1998 Forester
@Rinkerx The only concern I would have is older 2.5 did not have vvt, newer do.
Also verify egr pipe in the head.
Other than that, the block is the same, oil pan and cam crank gears can be different.
Sent from my SM-N975U1 using Tapatalk
1 - 2 of 2 Posts
