After driving on some washboarded gravel roads in Oregon my stock radio simply stopped producing any sound. It would turn on and the screen would show that the radio was changing channels and volume changing, but there was absolutely no sound. I ignored the problem for a while and then the radio stopped working altogether with the exception of the green lighting. That lighting on the radio still comes on when I turn on the ignition but that's it.
I've checked the radio fuse under the steering wheel and the other 15A fuse for the clock, etc. under the hood and they seem fine based on a visual inspection. I pulled out the radio and the connections to the wire harness seem secure with a little tug test. I tried disconnecting the car battery and resetting everything with no luck.
Any additional suggestions? Thank you!
