This is applicable for the sh5! We have the vdc as well. Hmm... I'll give this a thought when and if ever I do reach that 400 whp. Thanks for sharing! Might be applicable to another club member. I'll let him know
In the MPT transmission the signal that controls the MPT engaging the rear drive is interrupted by inserting the fuse. In the VTD transmission, that signal is used to control the clutch pack that changes the power distribution from 45/55 to 50/50. So with the fuse in, the torque distribution is entirely based on the gear configuration, and not the clutch pack, giving you a constant rear bias.whats up with the FWD fuse in? does it disengage something like in my current stock 4EAT? or just keep the nagging AWD light away?
I'm pretty sure that the VTD basically behaves as an open diff without the clutch packs activated with a rwd bias when the FWD fuse is in. It would be like having dccd in open mode.In the MPT transmission the signal that controls the MPT engaging the rear drive is interrupted by inserting the fuse. In the VTD transmission, that signal is used to control the clutch pack that changes the power distribution from 45/55 to 50/50. So with the fuse in, the torque distribution is entirely based on the gear configuration, and not the clutch pack, giving you a constant rear bias.
At least this is my simplistic understanding of it. If someone knows more about how this works, feel free to chime in.
Very interesting - please do post readings.So it looks like some testing is in order, I'll hook up a pressure gauge to the transfer port and measure pressure and voltage going to the transfer solenoid with and without the FWD fuse is, with the MPT still in place, and then with the VTD installed- should happen later this week
Very interesting too....as for the 03-4 Baja, I doubt the pinouts are the same, I'll look it up and see...
Sport shift is implemented on direct control 4EATs only I think.... I also wonder if I would also need the valve body for the sport shift to work, hmmm
I'm not sure about that, but thanks for the compliment!:icon_biggrin:Ok, it seems you know what you are doing.
It does seem that the 04 Baja was able to have VDC and a direct control 4EAT, I printed out the TCM input/output, and a lot of the pinouts are the same, but there are the pins for the sport shift that are different for the baja compared to my car, maybe others too.Sport shift is implemented on direct control 4EATs only I think.
Is the Baja direct control?
1.7's would be great, I would be happy with consistent low 1.9's as I'm not putting gobs of power down yet^I can not comment on actual 60' times but when comparing 2 different FXT's, one with VDT(275whp/270tq) MPT(27xwhp/3xxtq) The vdt car pulled times nearly a half second quicker. This was with different drivers, different tracks so take it with a grain of salt.
If I am correct, you should be able to launch it better and at least get into the 1.7's
Don't you SH guys already have VTD from the factory?Know of anyone doing this for the 09/10 fxt?
Hey MFB, yep same guysubarutech77, you the same one at RR right?
It looks like all 09-10 models of foresters have vdc according to subaru.com, so its most likely that you have a vtd center diff, I would try to get a look at the rear part of your trans, if it's kind of cone shaped it's a MPT- if it's more of a square shape it's a VTD.
Take a look at the pic in the first post of this thread- see the difference in the housings?
EDIT: just looking through an 09 and 10 FXT service manual and it only shows the MPT type center diff- I wonder how the VDC would react with this swap
Is there any front LSD for the 4EAT?This is way more cost effective for me than buying the LSD for the front differential I think.
