2006 - MPT to VTD conversion!
114018 Views 238 Replies 50 Participants Last post by  nutville
7
this mod is intended for US vehicles without VDC as all others (AFAIK) allready have this type of differential
edit: looks like 2007+ XTs have this as an option as per http://www.subaruforester.org/vbulletin/f63/usdm-forester-specs-options-prices-all-years-34187/#post435339
this mod will do little for your vehicle unless your making A LOT of power
as you can see the diagram has the first half of the part numbers (for the most part)..I have a wad of papers that finished them by Year Motor etc
Edit by admin: parts list and diagram attached and downloadable below.
if you copy and paste the part numbers into one of the OEM parts sites you can get a total cost..(note the quantities on some of them)...and they will put them in a box and ship them to you..then you (or your favorite transmission shop :icon_wink:) must assemble and install, however, this project will require the use of a shop press and some specialty tools (or their home made equivalent :icon_idea: )
This article explains this diff well: see downloadable 4eat.pdf attachment below
once this is assembeled installing it to the transmission is fairly straight forward...if you have never opened an automatic transmission this may not be a job for you :evilatyou:
here they are side by side left MPT right VTD
61 - 80 of 239 Posts
...4 wheel drifting in the rain :woohoo:
Glad you are happy!
How differently did it behave before the mod ? No 4 wheel drifting in the rain?
I 've read that no more front wheels spinning before the rears kick in but what about tight corner drifting?
How different is it now? Any snow/mud drift differences experience?
If you guys want to see the MPT version, check out this post.
http://www.subaruforester.org/vbulletin/f89/center-diff-22005/index2.html
Glad you are happy!
the computer that runs the MPT system want to see slippage of the front wheels before it sends power to the rear
this diff sends 55 percent of the power rearward without any computer guidance..
tight turns under hard acceleration is far more balanced feeling and doesn't have the binding feeling (and the rear will get loose if I want :biggrin:, which was almost impossible with the MPT)...
if you drive vehicals with each diff. you would notice the bind that all MPT equipped Subaru's have under hard acceleration with the steering wheel over hard
I don't take this car off road/out in the snow
Well winter weather made taking the FWD fuse out a plus (the front tires were spinning in the rain)
but when I get on it in first gear it triggers the flashing AWD light....the "it thinks the tires are of different sizes" thing...
a new TCU out of a VDC vehicle is ~$500 and I don't KNOW that it would work, I think the wire to that light is going to get cut
but beside the flashing light it works great...4 wheel drifting in the rain :woohoo:
Can you explain the fuse thing some more? Do you usually leave the fuse in permanently with the VDC conversion?
... tight turns under hard acceleration is far more balanced feeling and doesn't have the binding feeling (and the rear will get loose if I want :biggrin:, which was almost impossible with the MPT)...
Driving fast an MPT N/A I noticed that when I was suddenly lifting my foot from the gas pedal in a very tight corner, the tail would feel very light and this enabled me to easily flick the tail out and turn the corner with four wheels drifting pressing fully the gas pedal again.
This light feeling was fun but it was not a consistent behavior and I almost went off a gravel road when the tail proved too lightweight when I tried the same technique.
With the VTD conversion how much different the above may be?
Is the behavior more consistent? More difficult to flick the tail while braking and easier when accelerating?
Differences when braking INSIDE the corner? (The MPT is supposed to disengage more when braking...)
Any differences when hard braking when going straight ahead?
Thanks for the feedback!
I have used that technique to get the ass end of 1 ton vans loose..... :biggrin:
my main reason for this conversion was putting power to the ground in straight line acceleration..I had burned the MPT out and wanted something to put the power to rear
as stated in the OP this mod is only worth it if your making a lot of power...I am getting into the 450 WHP region
as for braking I don't have that many miles on this diff (motor went) but I have not noticed any difference, however I don't autoX or have much occasion to back shift and turn hard at the same time..but I imagine that the VTD would cause the rear to come around more in those situations than the MPT..hence vehicles with the VTD diff come with VDC
Thanks once more for the feedback!
Of what I have read so far I see that the VTD thing has a more consistent behavior than the MPT which is more unpredictable. Right?
..but when I get on it in first gear it triggers the flashing AWD light....the "it thinks the tires are of different sizes" thing...
I suppose that this may happen because with the MPT there is no way that the rear axle can spin faster than the front axle (not the wheels but the axles towards the diffs which are sensed by the TCU sensors) while with the VTD this can happen so it thinks of the "different size" issue.
the pin wheel for the rear VSS has less teeth on it than the MPT, I thought this would be a problem but it didn't show until I pulled the FWD fuse for winter..when I figure out a proper fix I will post it
If it is just a matter of pulses, an electronics guy can make you a pulse multiplier fix.
A microcontroller can count the time between the pulses from the sensor and load the proper timing value to its pulse generation circuit to achieve the required multiplier and feed the pulses to the TCU. Cheap stuff but may require some time to develop.
Any news?
Have you hooked up the VTD clutch?
Any news?
I am in the process of replacing the rear diff so the car is broke right now
I bought a new pin wheel for the rear speed sensor, I plan on grinding it down and using my wire feed to build it back up then cutting the same number of teeth as the MPT setup into it
I will update this thread when I have seen how that works
a speedo calibrator box would do the same job.
Good work andy. Just because I dont remember but are you still on the stock trans or are you ipt built?
... I plan on grinding it down and using my wire feed to build it back up then cutting the same number of teeth as the MPT setup into it
:icon_biggrin: hehe, going the simple and hard way! Electronics can make it easier and softer but if you have no-one around to fix this for you, it is better to stick with what you know.
Have in mind, this must be a "hall effect" inductive sensor so your hand made teeth must be around 0.5 to 1mm max away from the sensor.
...(and the rear will get loose if I want :biggrin:, which was almost impossible with the MPT)...
I think that this must be so because with the MPT the rear axle cannot rotate faster than the front axle during acceleration while with the not-yet-connected VTD (and the MT models until the LSD kicks in) it can, so you can have power oversteer when the rear axle rotates faster than the front (although on low grip conditions, the rear axle may not turn faster for oversteer to occur). When you properly hook up the VTD clutch, the oversteer should be reduced.
I do the same thing lol. The MPT also shifts power rearward with more throttle, but seems to shift it forward when you left off, so it behaves like a fwd car in regard to lift off oversteer.
Does anyone know if the pinout for the VTD TCU is the same as the MPT TCU? I'm thinking if my trans goes I'll try a full VTD 4eat swap.
wow... this is amazing news for any 4eat owner.... thanks for sharing this info!
do you know where to get one ?
stock execpt for the resistor , TC and VTD
I am going to keep the same diameter and hope that the teeth that I cut don't have to be too close together for the sensor to 'see'
the pinout in the FSM shows the same for both in the 06 FXT but I am pretty sure the programing is different as the VDC cars have different modules that communicate with it over the CAN bus
So if I go junkyard diving for a VTD center diff... is the general concensus that any 4EAT VTD diff will fit?
Also, anybody have any problems after conversion, other than the nagging AWD light?
Only the 2007 - 2008 Forester XT VTD diffs are confirmed to work
AFAIK, a6n6d6y is the only person on the forum to do the conversion.
I am pretty sure any 4EAT VTD will fit, I fit the one I put together to a 2002 4EAT core before I installed it to my transmission
I am working on the AWD light issue
