2005 Forester XS
Hello folks, new here to the forum and have a "burning" question - I have a 2005 XS with 87k miles, and seem to be using a quart of oil every couple of months. I don't see any evidence of a leak in my driveway. My local repair guy told me that Subies have known head gasket issues, and I'll need that replaced. My dealer told me that it's normal to use a quart of oil every 1,000 miles at this age. Anyone have any advice, comments, etc?
Thanks in advance,
Jeff
2016 & 2018 2.5i Premium CVT
I see that this is your first post, so welcome! I once lived in College Park.
That's not an especially unusual amount of oil to burn. One thing to check is the gasket on the oil filler cap. Mine disappeared on both my cars, so I had nothing to compare against till somebody else pointed it out to me. Consumption went down nicely when I replaced them.
Personally to me a quart every 1000 is to high. It shouldn't do that. You either have a broken ring or engine abuse.
Do check the complete PCV system for clogs and proper operation. When the piston and bore wears the chance for ring flutter ocurring under light load / high rpm increases exponentially and you will see oil usage from 700- 2000 miles/qt. Rebuild is the answer, but may be cost prohibitive at this point. Immediately, a somewhat more viscous oil will help a bit. If you are running Mobil clean 5000 5w-30, at your next oil change use 2 qt of 10w-40 Mobil clean in the mix. Also try Shell Rotella T-5 10w-30 or Pennzoil High Mileage 10w-30.
2003 XS MT
Welcome! My sis is getting her MBA at University of Maryland, I'm becoming more familiar with your area every visit.
I agree that 1 quart every 1,000 miles is too much.
As a comparison, I have an '03 XS 5 speed with 120k VERY hard miles on the clock. He goes through 1/2 quart every oil change (2800 miles).
