1 - 10 of 10 Posts
2005 Forester Sti
Why does the prop shaft have two sections where the splines are missing? See bottom right and top left here:
When I looked at the gearbox output male splined section it was fully populated so it wasnt like it was keyed... which is what I thought it was for?
Another example below... prop shaft and end view
2005 Forester Sti
Thats what I said above but there were no special double mating spines in the gearbox out shaft so the prop shaft could be inserted in any alignment
MY11 WRX STi Sedan 6MT
As mentioned above for alignment but only for when it is being balanced ??
2004 forester sti
Apparently they all like this , ive asked the question. So the male side is not the same which possibly rules out alignment and balancing .
Still its an interesting subject whilst drinking a tall gin crush (the world cant be that bad)
2014 2.5i Limited CVT
I would doubt the alignment suggestion - even if only it also appears to the threaded? I mean, you can't have a threaded insert that then matches up to an alignment key... because once you get so far in and the keys meet, then you can't thread it any further.
Unless the threaded section is for a completely different part - like a securing nut to hold the shaft in once aligned... so a separate piece.
Your "threaded" area is coarse machine turned finish.
Reactions: Lockheed
1 - 10 of 10 Posts
