Status
Not open for further replies.
2001 Forester S/STI Auto
Up for sale is my tastefully modified (Clean Title) 2005 Subaru Forester XT Premium that has undergone a complete Forester STI swap done correctly. I am the second owner and have all documented receipts for the last 12 years. The car was 100% stock when I acquired it from the original owner who was a 70 year old woman. This is probably the closest Forester XT to an actual Forester STI. Everything for the most part from the exterior, interior, and drivetrain has been addressed to the Forester STI spec or better. All parts configured on the car are high end and or have been discontinued JDM parts From: Prova, Endless, Fujitsubo, Zero Sports, Genome, HKS, Cusco, and Beatrush. Some other parts used such as: Whiteline and APS also. Everything else will be OEM Forester STI spec for the most part. The complete engine is from a 2013 STI GRB and had 25,983 miles dead when installed on Chassis at 253,000 miles. (I have video of the engine running from the car it came out of). Because it has a later year model EJ257, smog will not be an issue with using (OEM Down-pipe and OEM Cats). OEM VF48 STI standard turbo, newer OEM 2016 STI TMIC, DW740cc injectors, Full and complete APS Turbo Inlet (purchased new) with original receipts. It is super rare and a discontinued piece and is simply the best turbo inlet you can buy for your Subaru. Grimmspeed AOS (Air Oil Separator) routed neatly and connected to a Cusco oil catch can. Just in case the AOS misses any blow by. Ive never had any oil in the actual catch can. The engine is probably the one of the healthiest EJ257 STI motors because it doesn't burn a drop of oil. I check my oil every other fill up when getting gas and it's always right below the full mark. so I've never had to add or top off oil. (Using Redline 5w30) or (Eneos 5w40) and changed every 3,000 miles. The car has been fully tuned by Sean at Metro Performance and it is now making a conservative 251awhp and 309wfpt at 18psi. I wasn't looking for high power outputs. Just simply reliable power for everyday, daily driving that would safely keep the motor strong and healthy. The Exterior and Interior are in excellent condition. Interior looks and smells new and seats are in perfect condition with no rips, tears, or stains. Paint is in great shape with no deep scratches or dents. I will include a full parts list down below. If interested, and for more pictures feel free to contact me at anytime. Asking $21,000. The price is slightly negotiable.
Call or text is preferred - 626 230 1368 Chris
Engine & Exhaust Modifications
-2013 STI GRB EJ257 Complete Engine with Motor Mounts.
-2013 STI GRB VF48
-2016 STI TMIC, Y-Pipe, STI Throttle Body Coupler, and Grimmspeed BPV Hose.
-JDM 3" Fujitsubo Divorced High Flow Catted Downpipe (Heat wrapped)
-JDM 3" HKS Super Turbo Cat-Back Exhaust
-JDM Beatrush Forester STI SG9 Aluminum Radiator Cooling Shroud Gold Finish
-JDM Beatrush Forester STI SG9 Light Weight Alternator Pulley Gold Finish
-JDM Prova Unequal Length Race Headers
-JDM STI 1.3 Bar Radiator Cap
-JDM OEM Forester STI Hood Scoop
-Subtle Solutions Hood Scoop Splitter
-APS Turbo Inlet Pipe Complete Kit with all Hoses, Clamps, and Pieces Installed
-APS 65MM CAI with K&N Air Filter
-APS 50/50 BPV
-Cusco Turbo HeatShield
-Cusco Oil Catch Can
-Deatsch Werks DW200 255lph Fuel Pump with New Fuel Filter
-Deatsch Werks DW740cc SideFeed Injectors
-Cobb AP V3 Sub-002 with Full Pro-Tune
-Cobb 3port EBCS
-Grimmspeed AOS
-Grimmspeed Main Crank Pulley with Alignment Tool
-NGK 1 Step Colder Spark Plugs
-Mishimoto Transmission Cooler
-Optima Yellow Top Group 35 Battery
Suspension & Handling Modifications
-JDM Cusco AutoBacs Pro Coilovers with New Gruppe N Front Upper Strut Mounts
-JDM Zero Sports STI 25MM Front Sway Bar + Energy Bushings & Mounts
-JDM STI GDB Front Titanium Strut Bar
-JDM STI GDB Spec-C 20MM Pink Rear Sway Bar
-JDM STI GDB Spec-C Pink Trailing Arms with Pillow Ball Bushings
-2007 STI GDB Steering Rack & Cross Member Assembly
-2007 STI GDB Aluminum Control Arms
-2007 STI GDB Aluminum Rear Lateral Links
-Kartboy Front & Rear Endlinks
-Whiteline Steering Rack Bushing Kit
-Whiteline Rear Subframe Locking Bolts
-Whiteline Center Roll Kit
Wheels, Tires, & Brakes
-Volk Rays CE28N 5x100 18x8 +44 New Volk Valve Stems & Caps, and New Volk Centering Rings
-JDM STI Aluminum Black Lug Nuts
-Bridgestone Potenza 760sport 245/40/18 (Full Set)
-Dunlop Maxxsport 245/40/18 (Full Set)
-Endless Racing 6piston front Calipers
-Endless Front Brake Pads
-Endless Brake Lines
-Dixcel Front Rotors
-2007 Subaru WRX 2piston rear Calipers
-Stop-Tech Rear Slotted/Vented Rotors
-Hawk HPS Rear Ceramic Brake Pads
-Kartboy 2 Pot Rear Big Brake Adapters
-Motul 660 Race Brake Fluid
Interior
-JDM Forester STI SG9 Black Alcantara Front & Rear Seats
-JDM Forester STI SG9 Door Cards
-JDM Forester STI SG9 Door Sills
-350MM Zero Sports STI Steering Wheel with Original Box (Ultra Rare and Brand New)
-2007 Subaru STI GDB Airbag
-2007 OEM STI Black Floor Mats (Brand New)
-Alpine INE-W960 Double Din Touch Screen Head Unit with DVD Player, Navigation, Blue Tooth, and Mic/Speaker
-OEM Rear Privacy Cargo Cover
Exterior
-JDM Subaru Forester SG5 Cross Sports Complete Front Bumper and Bumper Support with Optional Cross Sports Full Front Lip
-JDM Subaru Forester SG5 Cross Sports Honey Comb Front Grill
-JDM Subaru Forester STI SG9 Rear Spoiler with Brake Light & Brake Light Cover
-JDM Subaru Forester STI SG9 HID Silver Housing Headlights
-JDM Subaru Forester STI SG9 Rear Bumper (Rear Spats Included but not Pictured)
-JDM Subaru Forester STI SG9 Side Skirts + Spats
-JDM Subaru Forester STI SG9 Black Housing Tail Lights
-OEM STI Rear Badge
-OEM Subaru Yakima Snowboard Racks with 2 Keys
-New Windshield
-Hella Horns Painted Black
-LED Headlight Bulb Upgrade
Additional items that are included with sale:
-Subaru STI GC8 V6 Type-RA 5speed Manual Transmission with DCCD
-Matching R160 LSD Rear Differential
-JDM Genome STI Boost, Oil Temp, & Water Temp Gauge with all Sensors, and Harness
-JDM Subaru STI GDB Titanium Piston Shift Knob
-JDM Forester STI SG9 Doors Complete with Door Cards, Door Moldings, Tinted Windows, Folding Power Mirrors with Mirror Gaskets, Power Switches, and Window Motors
-2008 Subaru Forester Door Moldings
-2008 Subaru Forester Center Console + Extended Arm Rest
-2008 Subaru Forester Manual Pedal Assembly
Status
