1 - 20 of 173 Posts
2005 XTEn Auto
Error codes P1410 P2441
Quite a few people had posted on my threads about Sec Air that the easy solution was to disable the errror codes but I couldn't find anyone who had done this without using a tuner. Well here is a brief writeup of how i did it.
First a warning, if this goes wrong you have to transport your Forester to a dealer and have a new ecu fitted.
Buy a £10 VAG cable of Ebay
Download RomRaider and ECUFlash
Spend a month getting the lead to work with the RomRaider drivers and then getting the ecu to connect with the programs.
Spend another month working out how RomRaider and EcuFlash work.
Get up enough courage to pull the ecu rom, disable all the Sec Air error codes and then flash it back in.
Definitely ain't easy and not for the faint hearted or computer illiterates, but it worked :woohoo:
Max.
Update.
It appears the ecu on non-turbo cars with the air system can't be accessed to delete the codes. See Post 93.
Update,
2007 models are CAN-bus and the ecu can only be read with a genuine Tractrix cable. See Post 102
2005 XTEn Auto
Basically as my first post, here is stage one.
Download and install this version of Java Old Version of Java Runtime Environment 1.5.0.16 Download - OldApps.com
Download and install Rom Raider and Ecuflash
Don't load the driver disc which came with the cable. Plug in the cable to your laptop and it should find the two sets of drivers automatically, otherwise point it to C/programs files/openecu/ecuflash/drivers.
Read all the RR Documenation, download ecu definitions etc, plug the cable into the obd port and then the laptop and see what happens.
Read all the entries on the RR forum for "won't connect". Eventually you'll get there.
If you get stuck repost here.
Max
1999 forester s turbo
If you look around the bay you will get the cable a lot cheaper. Mine cost 99p and it's the same one.
2005 XTEn Auto
Can you post up the link. I could do with a spare.
Thanks,
Max.
2005 XTEn Auto
Discussion Starter #7
Brain fade again, the drivers for the VAG cable are in C/programs files/openecu/ecuflash/drivers, not in RomRaider.
Apologies if I have lead you astray.
Max.
none none
Just FYI, if you're going to be flashing, the tactrix cable is probably the more reliable solution than the vagcom cable (as its designed specifically for flashing subarus), however it is quite a bit more money. I've seen a few people unable to flash (especially on the 06+ canbus cars) with the cheaper cables.
2005 XTEn Auto
Discussion Starter #10
Tractrix cable is $169+carriage+vat+import tax to the UK, so the £10 VAG cable is definitely worth a try to start with. According to the EcuFlash forum if the cable reads the ecu and does a "test write" it is ok for flashing.
I think the Secondary Air problem only affects 06/08 SG models so Canbus isn't an issue.
Max.
06 Forest XT Ltd
Secondary Air Pump
Excuse me if this is a silly question, but wouldn't a reflash only be a temporary solution as the computer would read the problem pretty quickly again?......or are you telling the computer to stop reading that system altogether?
2011 Volvo XC60 Auto
Yep, you can reset the error, but chances are it will come back....mine did twice before the valves were replaced
Interesting info on the plastic coated valves, does that mean that history will not repeat itself
2005 XTEn Auto
Discussion Starter #13
If you reflash the ecu this permantently stops the errors being read even if the fault is still present.
A code reader will cancel the error codes till the next time the fault occurs.
Max
06 Forest XT Ltd
Max
Oh....so I see the advantage now to having a tune done if this happens.....save you @ $1500 and give you a little boost at the same time...nice!
2011 Forester 2.5X Lim. Automatic
If you have an Accessport you can do the same thing (turn off the CEL for certain codes, and the computer will stop reporting the error). My car has passed an OBDII type emissions inspection for the past 3 years like this. You need to download the free Accesstuner Race software in order to do it.
MY11 WRX STi Sedan 6MT
All very interesting, but as you are posting in the "Europe" section and Accessport doesn't apply to EDM vehicles.............................:confused:
2005 2.5 XTE
Right..... I've got the log from the car on the computer within ecuflash and saved it. I've opened the log on RR software and turned off the troublesome codes but having trouble saving the log to a hex file so that ecuflash can see it and I can flash the ECU.
Surprised I've got this far!
Any pointers?
Cheers
2005 2.5 XTE
S'alright! sorted it.
Didn't really need RomRaider and did the editing on ECUFash. great result all for less than a tenner. Which is a good job as the foz has just been through an MOT(sailed through) and the tester has said it will fail next year for ECU management light :crazy:
2005 XTEn Auto
Discussion Starter #20
Any pointers?
Cheers
Well done glad you got it sorted. Was the problem with saving the file the "user level" setting?
Don't forget to pull the fuses for the valves and air pump.
Max.
1 - 20 of 173 Posts
