1 - 2 of 2 Posts
hey guys so I drive an 05 5speed and this was the second time this has happened in the past month that I was driving and lost acceleration and the car went into limp mode at around 2K RPM and check engine light came up. Both times I cruised to the side of the road, turned off the car for a minute then started her back up and drove home no problem. I also experience a spike in RPMs (goes up to 4-5K while coming to a red light or any stop, very embarrassing) frequently while shifting between gears and in neutral with the heat on. Drove all summer with no problem/codes/revving, this only happens when I turn the heat on, thanks guys.
First off use Advanced Search for "P2138" and you'll find lots of discussions. I also found a discussion here:
1 - 2 of 2 Posts
